1/26/2012 3:16pm - Uplink Activity Report - 17 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 1/26/2012 3:16pm - 17 changes
Uplink Comparison Range: 01/26/2012 03:01P - 01/26/2012 03:16P
Channel Additions:
470 - NBA [182] added to EchoStar14 119W TP 18 ConUS beam (NBA League Pass) (NA)
470 - NBA [182] added to Nimiq5 72.7W TP 05 ConUS beam (NBA League Pass) (NA)
475 - NHL [182] added to EchoStar14 119W TP 18 ConUS beam (National Hockey League Center Ice) (NA)
475 - NHL [182] added to Nimiq5 72.7W TP 05 ConUS beam (National Hockey League Center Ice) (NA)
608 - FRNCH [182] added to EchoStar14 119W TP 18 ConUS beam (NA)
608 - FRNCH [182] added to Nimiq5 72.7W TP 05 ConUS beam (NA)
612 - RUSIN [182] added to EchoStar14 119W TP 18 ConUS beam (NA)
612 - RUSIN [182] added to Nimiq5 72.7W TP 05 ConUS beam (NA)
613 - ISRLI [182] added to EchoStar14 119W TP 18 ConUS beam (The Israeli Network) (NA)
613 - ISRLI [182] added to Nimiq5 72.7W TP 05 ConUS beam (The Israeli Network) (NA)
614 - CHNSE [182] added to EchoStar14 119W TP 18 ConUS beam (NA)
614 - CHNSE [182] added to Nimiq5 72.7W TP 05 ConUS beam (NA)
615 - TAIWN [182] added to EchoStar14 119W TP 18 ConUS beam (NA)
615 - TAIWN [182] added to Nimiq5 72.7W TP 05 ConUS beam (NA)
624 - VIET [182] added to EchoStar14 119W TP 18 ConUS beam (NA)
624 - VIET [182] added to Nimiq5 72.7W TP 05 ConUS beam (NA)
Channel Removals:
615 - VIET (NA) [182] removed from Anik F3 118.7W TP 15 ConUS beam
Channels in the system: 8458
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2012 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v11.12.22
© 2012 - All Rights Reserved - SatelliteGuys Incorporated
What are they doing? Are these going to stay here? Less than a year ago they took my 61.5 said I:d never need it again, put in 77. Middle last week they took locals off 77 and came to adjust to 61.5 . So I thought I might try the Israel channel on 61.5 which I knew had the foreign channels, my mistake they changed them to 118.
I think these are going to be channels advertising the foreign channels they have available at 118.7. Many DISH customers have no idea all of these foreign channels are available to them!
Can you explain them saying not needing 61.5? That may be the first time I ever heard that. Even when your locals were on 77, you needed 61.5 and 72 to get all the channels. (Unless you didn't mention you also have the Western Arc)
Tampa
IN some areas they were installing WA dishes for HD (instead of mixed arc). Then Dish adds HD locals on 77W so techs installed a 2nd dish (at the time they were told that....now they do a EA dish)
A couple weeks ago they moved the 77W locals to 61.5 so now folks need a new upgrade (or swing the dish to 61.5)
I think what the poster meant was if you move to WA you normally wouldnt need 61.5
Tampa
I think my thought was close to what you are saying. His HD locals maybe were only on the EA, he already had the WA perhaps prior to HD. Never made switch to EA.
I just realized a few days ago that my local channels have been on four different satellite locations now. First 105, then 129 then 77 then 61.5. At least each time they did the move it was a better location (other than 129 but it was easier to deal with than a dang SuperDish).
I called this afternoon to see about getting a 118 , I think she said $200 plus $99 to get it installed. I have a hearing disability so I can't be sure. I think I"ll wait till the hopper comes out and hope to get it cheaper.
I think it's much less than that. Maybe $100 or so. A dirt team member could tell you.
IF you need a dish upgrade due to international channels moving I think there is no charge to do it.
edit: found a post I asked when the whole 77 HD locals moved to 61.5 I asked if there was a charge to switch from a WA +77 to a EA and Mary said
If DISH Network forces the upgrade by moving programming orbitals, then "No" the DISH re-point will be free of charge.
D
1/26/2012 3:16am - Uplink Activity Report - 29 changes
D
1/30/2012 5:01am - Uplink Activity Report - 2 changes
