4/19/2012 2:16am - Uplink Activity Report - 31 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 4/19/2012 2:16am - 31 changes
Uplink Comparison Range: 04/19/2012 02:01A - 04/19/2012 02:16A
Channel Additions:
5280(16) - WGXAD [MPEG4 HD] added to EchoStar15 61.5W TP 28 ConUS beam (Mkt:Macon, GA-Macon, GA-N/A) (A) (H)
5281(13) - WMAZ [MPEG4 HD] added to EchoStar15 61.5W TP 28 ConUS beam (Mkt:Macon, GA-Macon, GA-CBS) (A) (H)
5282(41) - WMGT [MPEG4 HD] added to EchoStar15 61.5W TP 28 ConUS beam (Mkt:Macon, GA-Macon, GA-NBC) (A) (H)
5283(24) - WGXA [MPEG4 HD] added to EchoStar15 61.5W TP 28 ConUS beam (Mkt:Macon, GA-Macon, GA-FOX) (A) (H)
6821 - UP5 [MPEG4 HD] added to EchoStar15 61.5W TP 02 ConUS beam (Virtual Channel) (NA)
Channel Removals:
5280 - KATC (A) (H) [MPEG4 HD] removed from EchoStar15 61.5W TP 02 ConUS beam (Mkt:Lake Charles, LA-Lafayette, LA-ABC)
5281 - KLFY (A) (H) [MPEG4 HD] removed from EchoStar15 61.5W TP 02 ConUS beam (Mkt:Lake Charles, LA-Lafayette, LA-CBS)
5282 - KPLC (A) (H) [MPEG4 HD] removed from EchoStar15 61.5W TP 02 ConUS beam (Mkt:Lake Charles, LA-Lake Charles, LA-NBC)
5283 - KVHP (NA) [MPEG4 HD] removed from EchoStar15 61.5W TP 02 ConUS beam (Mkt:Lake Charles, LA-Lake Charles, LA-FOX)
Channel Moves:
5284 - WMUM [MPEG4 HD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar15 61.5W TP 28 ConUS beam (Mkt:Macon, GA-Cochran, GA-PBS) (A) (H)
7881 - WGNM [MPEG4 SD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar15 61.5W TP 28 ConUS beam (Mkt:Macon, GA-Macon, GA-IND) (A) (H)
7883 - WPGA [MPEG4 SD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar15 61.5W TP 28 ConUS beam (Mkt:Macon, GA-Perry, GA-ABC) (A) (H)
5285 - KLTL [MPEG4 HD] moved from EchoStar15 61.5W TP 02 ConUS beam to EchoStar15 61.5W TP 27 ConUS beam (Mkt:Lake Charles, LA-Lake Charles, LA-PBS) (A) (H)
6477 - WTAE [MPEG4 HD] moved from EchoStar15 61.5W TP 20 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-ABC) (A) (H)
6478 - KDKA [MPEG4 HD] moved from EchoStar15 61.5W TP 20 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-CBS) (A) (H)
6479 - WPXI [MPEG4 HD] moved from EchoStar15 61.5W TP 20 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-NBC) (A) (H)
6480 - WPGH [MPEG4 HD] moved from EchoStar15 61.5W TP 20 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-FOX) (A) (H)
6482 - WPCW [MPEG4 HD] moved from EchoStar15 61.5W TP 20 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Mkt:Pittsburgh, PA-Jeannette, PA-CW) (A) (H)
6483 - WQED [MPEG4 HD] moved from EchoStar15 61.5W TP 20 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-PBS) (A) (H)
8134 - WPMY [MPEG4 SD] moved from EchoStar15 61.5W TP 20 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-MY) (A) (H)
8137 - WPCB [MPEG4 SD] moved from EchoStar15 61.5W TP 20 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Mkt:Pittsburgh, PA-Greensburg, PA-REL) (A) (H)
8142 - WINP [MPEG4 SD] moved from EchoStar15 61.5W TP 20 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Mkt:Pittsburgh, PA) (A) (H)
6828 - UP6 [MPEG4 HD] moved from EchoStar15 61.5W TP 08 ConUS beam to EchoStar15 61.5W TP 20 ConUS beam (Virtual Channel) (NA)
14240 - KVHP2 [EPG] moved from EchoStar15 61.5W TP 02 ConUS beam to EchoStar15 61.5W TP 27 ConUS beam (OTA EPG:Lake Charles, LA)(NA)
14843 - KLTL2 [EPG] moved from EchoStar15 61.5W TP 02 ConUS beam to EchoStar15 61.5W TP 27 ConUS beam (OTA EPG:Lake Charles, LA)(NA)
15200 - KLTL3 [EPG] moved from EchoStar15 61.5W TP 02 ConUS beam to EchoStar15 61.5W TP 27 ConUS beam (OTA EPG:Lake Charles, LA)(NA)
Channel Renames:
5280(16) - WGXAD (Mkt:Macon, GA-Macon, GA-N/A) - EchoStar15 61.5W TP 27 ConUS beam renamed to KATC(12) (Mkt:Lake Charles, LA-Lafayette, LA-ABC) (A) (H)
5281(13) - WMAZ (Mkt:Macon, GA-Macon, GA-CBS) - EchoStar15 61.5W TP 27 ConUS beam renamed to KLFY(6) (Mkt:Lake Charles, LA-Lafayette, LA-CBS) (A) (H)
5282(41) - WMGT (Mkt:Macon, GA-Macon, GA-NBC) - EchoStar15 61.5W TP 27 ConUS beam renamed to KPLC(7) (Mkt:Lake Charles, LA-Lake Charles, LA-NBC) (A) (H)
5283(24) - WGXA (Mkt:Macon, GA-Macon, GA-FOX) - EchoStar15 61.5W TP 27 ConUS beam renamed to KVHP(29) (Mkt:Lake Charles, LA-Lake Charles, LA-FOX) (NA)
Transponder Changes:
EchoStar15 61.5W TP 28 ConUS beam 21500 8PSK 2/3 added
Channels in the system: 8565
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2012 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.04.10
© 2012 - All Rights Reserved - SatelliteGuys Incorporated
I always thought Macon was on 61.5 on CONUS. Might be wrong. We at least they still have PITTS on Conus.
Why are they removing ConUS Locals from Lake Charles?
No...the software got confused. It thinks the channels were added and removed. Check TheList to make sure of the final layout.
I always get nervous when I see the Pittsburgh DMA locals on the uplink reports...
D
4/20/2012 11:16am - Uplink Activity Report - 2 changes
D
4/25/2012 6:31am - Uplink Activity Report - 10 changes
