Joey won't connect to the network.
jahost
186
Des Moines, IA
One of my Hoppers is a hard wire connect to the home network. The attached Joey will not connect. I have tried all the available resets and reconnects with no luck. Any ideas?
"Your wired network has a password? The neighborhood can't exactly steal your connection through an Ethernet cable."
I have both wired and wireless. I run a set of Apple Airports. I prefer wired but wireless is a option I often use. Hence the Joey issue....get it?
Your Joey won't connect to what exactly?
With the hopper hard wired, it does not send that connection to the Joey's. A hopper internet connector would connect all hoppers and Joey's to the network.
The only thing you lose by your Joey being hooked up to the network [its own IP] is DLNA support. All other content, BB@Home, DishOnDemand, and DVR content is accessed through the hopper itself.
Yes, it does.
isaacmorseMI said:
Yes, it does.
Be a little more specific.
No a hopper will not connect your Joey to your network with the Joey receiving its own IP address on your network. I have not tried this myself, but it has been talked about in length that the Joey must have its own connection to the network for dlna.
And a Hopper Internet Connector is the only way to connect all receivers to the network without hard wiring Ethernet to each one, or using a wireless adaptor/bridge.
Yes for DLNA it must have it's own connection, unless that was resolved in S208/S260. But for all other uses a hardwired Hopper is best.
The HIC is just fine for hardwiring purposes. Plus it's less troubleshooting for DLNA purposes. One connection point.
At this point, just about anyone doing hardwiring should just get it in the original install for free. At minimum as a backup in the event your network changes later on.
I guess I don't really have a problem. I assumed that since the Joey said "connection failed" on the broadband that I wouldn't be able to access the blockbuster movies. That does not seem to be the case. Sorry!
What do I get access to with the 250 on demand wise?
New Customer - Buying Additional Hopper?
