oldengineer SatelliteGuys Master Original poster Lifetime Supporter May 14, 2011 5,684 1,964 Lower Macungie Township, PA Jul 20, 2012 #1 I've got a tech visit in the next 30 mins to install a HIC in my 2H/2J syatem. Can I connect the HIC to a Hopper or does it have to be to a Joey? Thanks in advance for the answer.
J JM42 SatelliteGuys Pro Lifetime Supporter Nov 25, 2010 1,748 280 GA Jul 20, 2012 #3 oldengineer said: I've got a tech visit in the next 30 mins to install a HIC in my 2H/2J syatem. Can I connect the HIC to a Hopper or does it have to be to a Joey? Click to expand... Either, but if dropped off a Hopper line you must use a tap.
oldengineer SatelliteGuys Master Original poster Lifetime Supporter May 14, 2011 5,684 1,964 Lower Macungie Township, PA Jul 20, 2012 #4 JM42 said: Either, but if dropped off a Hopper line you must use a tap. Click to expand... Thanks, I assume the HIC output normally going to the Joey would be left open/terminated?
pweezil L.G.O.E. Supporting Founder Sep 8, 2003 386 23 N.H. Jul 20, 2012 #5 oldengineer said: Thanks, I assume the HIC output normally going to the Joey would be left open/terminated? Click to expand... Correct.
oldengineer SatelliteGuys Master Original poster Lifetime Supporter May 14, 2011 5,684 1,964 Lower Macungie Township, PA Jul 20, 2012 #6 pweezil said: Correct. Click to expand... Thanks for the help. The tech just left. One HIC connected up on a Hopper run with a tap to feed the Hopper. Works perfectly. DLNA apps now working.
