Homeland security says stop using Java
mike123abc
Too many cables
25,889
5,237
Norman, OK
Apple blocked java on macs:
http://www.macrumors.com/2013/01/11...n-os-x-to-address-widespread-security-threat/
Apple has, however, apparently already moved quickly to address the issue, disabling the Java 7 plug-in on Macs where it is already installed. Apple has achieved this by updating its "Xprotect.plist" blacklist to require a minimum of an as-yet unreleased 1.7.0_10-b19 version of Java 7. With the current publicly-available version of Java 7 being 1.7.0_10-b18, all systems running Java 7 are failing to pass the check initiated through the anti-malware system built into OS X.
http://www.zdnet.com/homeland-security-warns-to-disable-java-amid-zero-day-flaw-7000009713/
The U.S. Department of Homeland Security has warned users to disable or uninstall Java software on their computers, amid continuing fears and an escalation in warnings from security experts that hundreds of millions of business and consumer users are vulnerable to a serious flaw.
FF removed it automatically. This stinks because a lot of the websites I visit require Java. I cannot watch the live cams at some of my ski resorts now.
This is bad. What is oracle doing about this. How do you disable it on windows?
If you have chrome you can just go to chrome://plugins, scroll down to java and click disable. That is all I did, I left it working on IE. If I need to go somewhere with Java I will use IE.
The problem you have of course is that with a bad exploit like this you could be attacked anywhere. Even here if one of the ad servers gets hit like it did a few weeks ago.
You can also go into the control panel and uninstall java.
Or you can go into the java control panel and disable web browsing http://java.com/en/download/help/disable_browser.xml
Question-
Doesn't Blu Ray disk menus use Java in some fashion? I don't do much blu ray menu authoring but I wonder if there are any security issues possible if your player is using BD live?
My AV popped up and avised me I won't have a problem. It has the JAVA exploit under control. It also advises that JAVA still needs fixed though.
OS X Lion and Mountain Lion use the new security feature Apple added that let's them update a minimum revision level for software. Apple set it so the Java Runtime Environment had to be greater than 10.7.10_b29 which effectively disabled Java on those Macs that had it installed.
I know we're in trouble at work because we have an older web-based app the doesn't work correctly with anything newer than the version of JRE that it was written for. There has been some discussion of configuring IE to use Group Policy to enforce which Internet zones allow Java to run.
Programming Languages for Web Development
