9/11/2013 6:17pm - Uplink Activity Report - 27 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 9/11/2013 6:17pm - 27 changes
Uplink Comparison Range: 09/11/2013 01:16P - 09/11/2013 06:16P
Channel Additions:
6489(8) - KAIT [MPEG4 HD] added to Echostar16 61.5W TP 18 Spotbeam 63 (Mkt:Jonesboro, AR-Jonesboro, AR-ABC,) (NA)
6493(20) - KTEJ [MPEG4 HD] added to Echostar16 61.5W TP 30 Spotbeam 63 (Mkt:Jonesboro, AR-Jonesboro, AR-PBS,) (NA)
6681(3) - WREG [MPEG4 SD] added to Echostar16 61.5W TP 18 Spotbeam 63 (Mkt:Jonesboro, AR-Memphis, TN-CBS,) (NA)
6682(5) - WMC [MPEG4 SD] added to Echostar16 61.5W TP 18 Spotbeam 63 (Mkt:Jonesboro, AR-Memphis, TN-NBC,) (NA)
6683(13) - WHBQ [MPEG4 SD] added to Echostar16 61.5W TP 18 Spotbeam 63 (Mkt:Jonesboro, AR-Memphis, TN-FOX,) (NA)
6685(48) - KVTJ [MPEG4 SD] added to Echostar16 61.5W TP 30 Spotbeam 63 (Mkt:Jonesboro, AR-Jonesboro , AR-IND,) (NA)
6312(18) - WOHL [MPEG4 HD] added to Quetzsat1 77W TP 09 ConUS beam (Mkt:Lima, OH-Lima, OH-ABC,) (NA)
6313(38) - WOHLD [MPEG4 HD] added to Quetzsat1 77W TP 09 ConUS beam (Mkt:Lima, OH-Lima, OH-CBS,) (NA)
6314(8) - WLIO [MPEG4 HD] added to Quetzsat1 77W TP 09 ConUS beam (Mkt:Lima, OH-Lima, OH-NBC,) (NA)
6315(25) - WLIOD [MPEG4 HD] added to Quetzsat1 77W TP 09 ConUS beam (Mkt:Lima, OH-Lima, OH-FOX,) (NA)
6316(44) - WTLW [MPEG4 HD] added to Quetzsat1 77W TP 09 ConUS beam (Mkt:Lima, OH-Lima, OH-IND,) (NA)
6317(27) - WBGU [MPEG4 HD] added to Quetzsat1 77W TP 09 ConUS beam (Mkt:Lima, OH-Bowling Green, OH-PBS,) (NA)
298 - PREM [134] added to EchoStar14 119W TP 17 ConUS beam (A) (H)
298 - PREM [172] added to Nimiq5 72.7W TP 23 ConUS beam (A) (H)
Channel Removals:
6571 - KOLN (A) (H) [MPEG2 SD] removed from EchoStar10 110W TP 27 Spotbeam 29 (Mkt:North Platte, NE-Lincoln, NE-CBS,)
374 - SMITH (NA) [MPEG2 SD] removed from EchoStar14 119W TP 11 ConUS beam
374 - SMITH (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 05 ConUS beam
5741 - DPU (A) (H) [134] removed from Anik F3 118.7W TP 13 ConUS beam
Channel Package Flag Changes:
7795(11) - WMYG [MPEG2 SD] - EchoStar10 110W TP 23 Spotbeam 03 changed to Available (H) (Mkt:Gainesville, FL)
6575(25) - KNPL [MPEG2 SD] - EchoStar14 119W TP 05 Spotbeam A7 changed to Available (H) (Mkt:North Platte, NE)
9426(154) - NFL [MPEG4 HD] - Ciel-2 129W TP 30 ConUS beam changed to free preview (A) (NFL Network)
9426(154) - NFL [MPEG4 HD] - Nimiq5 72.7W TP 17 ConUS beam changed to free preview (A) (NFL Network)
9483(395) - SPMAN [MPEG4 HD] - EchoStar11 110W TP 22 ConUS beam changed to free preview (A) (Sportsman Channel)
9483(395) - SPMAN [MPEG4 HD] - Nimiq5 72.7W TP 30 ConUS beam changed to free preview (A) (Sportsman Channel)
9830 - ERT [MPEG2 SD] - Anik F3 118.7W TP 30 ConUS beam changed to Not Available (ERT World)
Channel Renames:
221 - BUY! - EchoStar11 110W TP 10 ConUS beam renamed to LEEZA (A)
221 - BUY! - Nimiq5 72.7W TP 07 ConUS beam renamed to LEEZA (A)
Channels in the system: 8922
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2013 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.09.27
© 2013 - All Rights Reserved - SatelliteGuys Incorporated
Just to make sure I didn't have a brain flake out or anything, does this say they are gearing up to possibly add HD locals for the Lima, OH market?
Does this mean the Memphis channels will still be in SD for the Jonesboro DMA?
Or will we be allowed to see the Memphis HD that is already turned on in the Memphis DMA?
Looks that way :)
Enjoy them when/if they become available.
yes
If you are on Eastern Arc you will get the stations in HD (EA is 61.5/72/77)
If you are on Western Arc you will still get them in SD (110/.119/129)
If you have HD receivers you should get a FREE dish upgrade once the stations go live (which can be next week, 2 weeks from now or never) ;)
Thanks.
Currently vip222 on Western Arc. Memphis has HD on both arcs. (because Jonesboro is SD only Dish can't turn on the HD Memphis here, yet) The Memphis western Arc HD spot is very weak here, about 20, hopefully the Eastern Arc is stronger. The sat maps seem to show it is stronger here. I hope they turn the HD on quick, 61.5 is going to be tight with trees, I need to know that I can get it before the leaves start falling.
Local cable has changed hands 3 or 4 times since I've been on Dish. ( Local cable still used a C-64 for local weather :) ) The latest owner has added HD, internet and a Little Rock local, making it a though decision.
Memphis is significantly viewed in my area. Let us have them as well
they can't. Per the agreement with the FCC to be allowed to sell a station outside of the local area Dish can only do "SV" if the market has a missing network (as in your case NBC). They can't import extra stations "just because"
Lima appears to be the only CONUS locals addition to 77W since they started moving other markets off 77.
D
9/15/2013 6:17am - Uplink Activity Report - 2 changes
D
9/16/2013 1:02pm - Uplink Activity Report - 2 changes
