3/10/2016 17:15 - Uplink Report - 36 Changes
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 3/10/2016 17:15 - 36 Changes
Uplink Comparison Range: 3/07/2016 05:31 - 3/10/2016 17:15 (PST)
Channel Additions:
125 - FXX [MPEG2 SD] added to EchoStar11 110W TP 11 ConUS (FXX)(A)
149 - FOXS2 [MPEG4 SD] added to Echostar16 61.5W TP 17 Conus (FOXS2)(A)
149 - FOXS2 [MPEG2 SD] added to EchoStar11 110W TP 02 ConUS (FOXS2)(A)
7660(61) - PBS [MPEG2 SD] added to EchoStar14 119W TP 08 ConUS (Mkt: Harlingen,TX (USA-PBS))(NA)(H)
9850 - LA7TE [MPEG2 SD] added to Anik F3 118.7W TP 12 ConUS (LA7TE)(NA)(H)
Channel Removals:
125 - INFO [MPEG2 SD] (NA)(H) removed from EchoStar14 119W TP 12 ConUS (Dish Network Information Channel)
6566(2) - LOCAL [MPEG2 SD] (A)(H) removed from Ciel-2 129W TP 15 Spotbeam 10 (LOCAL)(Mkt: Bend,OR)
7127(2) - LOCAL [MPEG2 SD] (A)(H) removed from EchoStar10 110W TP 18 Spotbeam 40 (LOCAL)(Mkt: Missoula,MT)
7188(2) - LOCAL [MPEG2 SD] (A)(H) removed from EchoStar14 119W TP 01 Spotbeam B2 (LOCAL)(Mkt: Eugene,OR)
8625(2) - LOCAL [MPEG2 SD] (A)(H) removed from EchoStar10 110W TP 12 Spotbeam 45 (LOCAL)(Mkt: Seattle,WA)
9181(23) - LOCAL [MPEG2 SD] (A)(H) removed from EchoStar10 110W TP 18 Spotbeam 40 (LOCAL)(Mkt: Spokane,WA)
9375(3) - LOCAL [MPEG2 SD] (A)(H) removed from EchoStar10 110W TP 12 Spotbeam 45 (LOCAL)(Mkt: Yakima,WA)
MAP Changed:
4149(240) - FXX [MPEG4 HD] Nimiq5 72.7W TP 06 ConUS map changed to (125) (FXX)(A)(H)
4149(240) - FXX [MPEG4 HD] EchoStar11 110W TP 22 ConUS map changed to (125) (FXX)(A)(H)
4943(240) - FXX [MPEG4 HD] EchoStar14 119W TP 01 Spotbeam B22 map changed to (125) (FXX)(A)(H)
5034(240) - FXX [MPEG4 HD] EchoStar14 119W TP 01 Spotbeam B22 map changed to (125) (FXX)(A)(H)
5306(240) - FXX [MPEG4 HD] Nimiq5 72.7W TP 06 ConUS map changed to (125) (FXX)(A)(H)
5306(240) - FXX [MPEG4 HD] EchoStar11 110W TP 22 ConUS map changed to (125) (FXX)(A)(H)
5560(240) - FXX [MPEG4 HD] EchoStar11 110W TP 22 ConUS map changed to (125) (FXX)(A)(H)
9520(240) - FXX [MPEG4 HD] Nimiq5 72.7W TP 06 ConUS map changed to (125) (FXX)(A)
9520(240) - FXX [MPEG4 HD] EchoStar11 110W TP 22 ConUS map changed to (125) (FXX)(A)
9613(397) - FOXS2 [MPEG4 HD] Nimiq5 72.7W TP 24 ConUS map changed to (149) (FOXS2)(A)(H)
9613(397) - FOXS2 [MPEG4 HD] Ciel-2 129W TP 19 ConUS map changed to (149) (FOXS2)(A)(H)
Tier Changed:
125 - INFO [MPEG4 SD] Echostar16 61.5W TP 12 Conus renamed to FXX , moved to Echostar16 61.5W TP 17 Conus , changed to Available , changed to Visible (FXX)(A)
9426(154) - NFL [MPEG4 HD] Nimiq5 72.7W TP 13 ConUS changed to (NFL Network)(A)(H)
9426(154) - NFL [MPEG4 HD] Ciel-2 129W TP 30 ConUS changed to (NFL Network)(A)(H)
9434(152) - MLBN [MPEG4 HD] Nimiq5 72.7W TP 26 ConUS changed to (MLBN)(A)(H)
9434(152) - MLBN [MPEG4 HD] Ciel-2 129W TP 18 ConUS changed to (MLBN)(A)(H)
9466(159) - NBCSP [MPEG4 HD] Nimiq5 72.7W TP 17 ConUS changed to (NBCSP)(A)(H)
9466(159) - NBCSP [MPEG4 HD] Ciel-2 129W TP 22 ConUS changed to (NBCSP)(A)(H)
9469(369) - MTVL [MPEG4 HD] Nimiq5 72.7W TP 24 ConUS changed to (MTVL)(A)(H)
9469(369) - MTVL [MPEG4 HD] Ciel-2 129W TP 19 ConUS changed to (MTVL)(A)(H)
9505(340) - ENCOR [MPEG4 HD] Nimiq5 72.7W TP 04 ConUS changed to (Encore (East))(A)(H)
9505(340) - ENCOR [MPEG4 HD] EchoStar11 110W TP 19 ConUS changed to (Encore (East))(A)(H)
Channel Moves:
5437(437) - FOXSE [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS moved to Echostar16 61.5W TP 05 Conus (FOXSE)(A)(H)
Name Changed:
9901 - AMDIA [MPEG2 SD] Anik F3 118.7W TP 07 ConUS renamed to INFO (Dish Network Information Channel)(A)(H)
Transponder Changes:
EchoStar14 119W TP 08 ConUS (21.500 8PSK 2/3) added.
Anik F3 118.7W TP 12 ConUS (20.000 QPSK 3/4) added.
EchoStar14 119W TP 07 ConUS (21.500 8PSK 2/3) removed.
Echostar16 61.5W TP 12 Conus (21.500 8PSK 2/3) removed.
EchoStar10 110W TP 12 Spotbeam 45 (20.000 QPSK 5/6) removed.
EchoStar10 110W TP 18 Spotbeam 40 (20.000 QPSK 5/6) removed.
Ciel-2 129W TP 15 Spotbeam 10 (20.000 QPSK 5/6) removed.
EchoStar14 119W TP 01 Spotbeam B2 (20.000 QPSK 7/8) removed.
Channels in the system: 9782
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.1
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
What is odd is that Harlingen HAS a PBS station....but its very unique
KMBH-DT2 (yes its a subchannel) is the PBS there. Its owned by MBTV TEXAS VALLEY
Its in HD so Dish could easily carry that. They usually only give you the national feed if there is no PBS in the market
Could it be KMBH-DT2 they are adding and just labeled it as PBS?
No
The station they added is the national pbs station. If it was a local it would have the call sign and be on the spot beam with the rest of the locals.
KMBH was previously owned by the Catholic diocese until 2014. They sold it to MBM which converted the license to commercial and has since moved PBS to the .2 and added Cozi Tv to the main channel. Dish carries the Cozi Tv channel. I think eventually they will drop PBS altogether.
3/11/2016 16:46 - Uplink Report - 2 Changes
3/12/2016 03:14 - Uplink Report - 2 Changes
