Tailgater and wally
Did you try disconnecting all coax, rebooting and doing a check switch with the coax unconnected? Then power down, connect the coax, and do another check switch.
Reactions: pattykay
Tried. Didn't help. The only thing different from last night (when all worked great) is the coax cable. Maybe it's a bum wire .....
Check and maybe replace connectors. Use compression not crimp.
Does the coax seem thin? Or have a kink in it?
RG-59 should be ok, but better to go with RG-6.
Hopper 3 transceiver firmware update?
Joey 3.0 low supply? And Hopper 3 to VIP series Comparison
