Only IF he wants HD....No ...
And remember you'll also have to connect a B-Band Converter (BBC) in each line from the legacy multiswitch to the HR24 receivers.
Sent from my LG-H932 using Tapatalk
Oh that's right, thanks ...Only IF he wants HD....
Aren't B-band converters only for HD or did that change?No ...
Its really an after thought seeing his set up only sees the 101 Sat which is strictly SD.Oh that's right, thanks ...
Jackonearth, disregard my last post ...
Yes.Aren't B-band converters only for HD or did that change?
slice - have you actually tried that? I think it should work but someone posted somewhere that it did not.
And why would you do that, spend all that money on a special SWM switch just to save one cable from the dish?
That's right it should work with a Genie, that's the setup I was looking at but this article says it won't work Can you use a Genie DVR in your RV or boat? - The Solid Signal Blog but this page says every receiver, including the Genie will work DIRECTV Compatible Satellite Antennas for RV, Camping, TailgatingI don't see any reason that you shouldn't be able to use a 101 only dish with an HR24, with or without a SWM switch.
It should even work with a Genie (obviously only if the 101 dish is connected to a SWM since it doesn't support legacy) despite the menu option for an 18" round dish having been removed. Just tell it you have a Slimline 3 with a SWM multiswitch, ignore and continue past the red X's you'll get after satellite setup for 99 & 103, then set your guide to hide HD channels.
I'm not sure about that Winegard $190 switch anymore. I'm starting to think it's just a standard SWM8 switch with a splitter included. I've seen the SWM8 switch elsewhere for a lot less.slice - have you actually tried that? I think it should work but someone posted somewhere that it did not.
If I were faced with this issue I would be spending as little as possible on my RV solution because no-one knows what will be happening when SD goes away next year.That's right it should work with a Genie, that's the setup I was looking at but this article says it won't work Can you use a Genie DVR in your RV or boat? - The Solid Signal Blog but this page says every receiver, including the Genie will work DIRECTV Compatible Satellite Antennas for RV, Camping, Tailgating
So you're saying I should go with Dish Network insteadIf I were faced with this issue I would be spending as little as possible on my RV solution because no-one knows what will be happening when SD goes away next year.
See? I asked at least twice on here if connecting the HR24 directly to the RV dish without a switch would work and never got an answer until now.I agree, I would not spend money on an SD-only solution. Just connect one HR24 directly to your dish (two cables, or one cable if you are happy with a single tuner), and wait until DirecTV reveals its solution for RVs.
I thought such as back in your post #13 you wanted two HR24s in the RV?See? I asked at least twice on here if connecting the HR24 directly to the RV dish without a switch would work and never got an answer until now.
In any case, I get the impression that Directv doesn't care much about RV customers so I think I'll take your advice and wait.
Thanks for all the help
