U518@1:21 AM.
Strange thing - my Hopper3 started the update (got the usual "downloading..." window, etc). When I came back to check on it, the Hopper was in Standby mode - I went the diagnostics screen to check the version and it was still on 517. I tried forcing the update again and now it tells me that 517 is the "latest software". Did they change their mind?
Same thing happened to me.
Reactions: xfoneguy
Yes it does. This update fixes the Hopper to Hopper DVR trick plays and it also fixes the old problem with EHD's spinning up correctly and not playing something on the first try.
Hallelujah!!!!!!! That H3 to H3 playback matter was a big PITA! I await the download; I don't want to force the download it before I hear more from those about what things this update BROKE.
I've been having problems off-and-on all day - ever since the update started this morning, and then failed....I couldn't get video on any of the Joeys - I could see guide info and other text, but no picture or sound. Very strange. Rebooted everything with no success. I finally unplugged the H3 for a bit, restarted it and now everything seems to be working again. Not sure what that was all about but I'm in no hurry to see this thing try to update itself again ......
Same ting happened when updating the hopper with sling this morning.
Hard boot - then force the update again.
Sent from my iPhone using SatelliteGuys mobile app
Reactions: xfoneguy
Hopper 3 to Hopper 3 partially fixed. It worked on one Hopper but not the other...strange. On one Hopper it worked just fine, but going the reverse way it still had problems, but not and many as before.
Seeing lots of trick play/playback issues on both Hopper3 and Joey 2.0 since this update. Problems observed:
1. Losing place on resume. That is, not resuming anywhere close to where the playback was stopped, as opposed to 20 seconds after playback stopped prior to the update.
2. Skip-forward/Skip-back being more inconsistent. That is, skip forward can be much more than 30s, and skip back can be less than 10s.
3. The return of the inserted ads on skip-forward problem I reported before. This is where ads are inserted over show content after a skip-forward. I hadn't seen it in weeks.
How long did you wait before checking on it? On both my Wally and Hopper Duo, I have seen them briefly go back to the regular screen-saver in the middle of a download, before resuming the download. So, it is important to actually watch the download progress, and make sure that the progress bar goes all the way across. In other words, it is possible that you interrupted it in the middle of the download. Additionally, on a Hopper, even when it looks like the download is done, it is important to leave it in standby for at least another half-hour or so, to make sure that it also downloads the Joey software, etc.
Reactions: xfoneguy
I have a HWS, but the same thing happened to me.
When I went into the 'Tools' setup and selected to download the new software, the receiver downloaded software, and the progress bar went slowly all the way up to 100%. Then the receiver booted up. Although it went through all of the motions as if it had downloaded and installed new firmware, when I checked, I still had U249 and not the new U700. This same thing has happened to me many times before.
I am pretty sure that you cannot download new firmware unless your receiver is on Dish's list of receivers that are eligible to receive the new firmware. This is so that Dish can control the number of receivers that get new software and see if there are problems before releasing it to everybody. Just because some people have the new firmware does not mean that you can download it to your receiver. Forcing the download will only work IF your receiver is 'on the list' of receivers that are authorized to get the new software
I wonder if DISH change's the list around sometimes! When I had HWSs I was always first on the list. With my H3s I am not first on the list but I was always able to do the forced software upgrade later on in the day when the update first appeared on other's Hopper 3. Now with the U518 update I can't get the force download to work. So DISH has changed the list around or they have put a stop to it because of issues. No one else seems to be reporting that they now have U518 so I kind of think U518 has been stopped.
Reactions: xfoneguy
Yes, I think Dish does change your receiver's position on the list, so that the same people are not the guinea pigs for the new software. When U249 was released, I was among the first to get it, however, most of the time, I do not get the new release (and cannot download it) for a few weeks (or longer if there were serous problems).
That makes since but it sure wasn't that way when I had four HWSs. I had the HWSs for four years and always got the software update on day one. I got my HWSs when they first came out. I didn't get my Hopper 3s until they were out about a year and a half because I was waiting for the DPH42 switch. I just thought the list was made up by who got their DVRs first and so on.
Reactions: xfoneguy and bspei
Moving Satellite To Another Location In Yard
