Tell me again why I should go from the HWS to the H3?
Because I have seen none of that behavior on college football Saturdays....Tell me again why I should go from the HWS to the H3?
After upgrading my TV and receiver to 4K capability, my picture periodically goes blank. It was doing this before the upgrade, but it would just blank for 5-10 seconds then come right back. Now it blanks long enough for the TV to say Loss of signal. I've unplugged and replugged the cables, banged on top, etc and it eventually comes back. I'm on my way to get 4K HDMI cables as I'm not sure if my older Rocketfish cables are the issue. They're the gold end type and think they're good up to 1080i.
Thought I'd throw this out there to see if others have experienced this issue.
What TV (model) did you upgrade to? It may only be an 8 or 10 bit panel.
Well if it's a really good day (like four SEC games at once) I am working the hell out of that app. Going big, back to multi, going back and forth, running the red select to listen to the various audio tracks etc.Because I have seen none of that behavior on college football Saturdays....
I would upgrade HDMI cables - I had older 4K cables and decided to get some better high ends and I've noticed a little difference in picture and response.
I don't have the issues your describing with my LG 65" OLED or H3 either... running smooth as a babys bottom in single and multiview.
Case in point from the beginning is cables do go bad..they will fail so don't assume they are good still even if you haven't touched them.
I would rule out the cheaper possible causes first... then swap TV's if you have another 4K version and see if it does it then. If not then you know it was the TV..if so and you swapped cables then clearly its the H3.
Pixelated locals, EHD's disappearing and ummmm, ummmmmm, ummmmmmm, oh yeah! 16 Tuners!Tell me again why I should go from the HWS to the H3?
I think the connectors to go between the cables can be an issue also. Might be easier to change those connectors out than to shorten the cable length.In addition to new cables, you may want to determine your total cable run length.
I have a 4K mounted on a wall, so cable 1 runs from TV to an upper jack on wall, cable 2 is the in-wall cable, and cable 3 runs from second lower wall jack to AVR. I needed to shorten the total length of the cables to stop my intermittent picture flickering. My 1080p TV which I replaced didn't not have a problem, but the 4K TV did.
I did a quick google search and 50 feet was the maximum length for 4k signals over HDMI. 25 feet was the expected length. And you only count from device to device. So in your case, it's not 3m from the DVR to the TV, but the 2m from the AVR to the TV that counts.Good thought. Mine is wall mounted but everything is close. TV to AVR is 2m. H3, Roku, DVR to AVR are all 1m.
Follow up: received the Pioneer Elite VS-LX103 last Tuesday, have had it all hooked up since then. Have watched several BluRays (GOT dragons are something with this setup), have watched shows off the H3 via channels, local and not, and off the DVR. Have watched a couple things off the Roku.
Not one screen blank!!
So it was either the AVR, cables, or combo of the two.
Always been a Pioneer person and should have stuck with them originally. The AVR I replaced still works great and I bought it in 1991. Lesson learned.
Bonus for any of you looking to upgrade your AVR, this model is $200 off at BestBuy until end of March. I'm not a spokesman, just a satisfied customer.
Thanks for everyone's recommendations and feedback. Makes these forums great!
-les
