DPH42 Ports
tcreek
SatelliteGuys Guru
125
37
North Pole, Alaska
Have a Traveler 1000 and replaced the feed arm. Old one had a slight bend in it. Forgot to mark where each connector was connected on the LNB. Instructions from Winegard says it doesn't matter where each connector is. But since I have a DPH42 and Hopper 3, does it matter to the DPH42 which LNB port is tied to each of it's ports?
The DPH42 inputs order doesn't matter, but your H3 should be connected to Port 1 output like so:
It doesn't matter which ports are used, either input or output. The power inserter should be connected to output port 1 though.
