Are sun outages a thing of the past?
DJ Lon
647
689
Phoenix, AZ
When I had my Dish 500 originally installed in the mid-2000s around the Spring and Fall equinoxes there would be a temporary channel with a slate explaining what sun outages were and for a few days one would actually lose signal for a couple of minutes in the afternoon. I haven't noticed this with my new installation. Are the satellites that much more powerful or the technology better now than back then?
Just curious
No, sun outages are still in place twice per year and do some effect on sat-system performance. Perhaps you did not sit in front of the TV screen at the proper time of the day. Explore THIS site to find out exact date, time and satellite position when sun outage happens at your location.
They usually happen in May from past experience.
Just curious
Most of the sun outages that happened on the big dishes used for receiving the signals from all the different providers at Dish have been eliminated because so much of the content is delivered by fiber now.
With the high powered DBS satellites that Dish uses as you noticed there's very little if any sun outages anymore. :)
In the past I made some experiments during sun-outage periods. Results of one of them represented on the picture. You can clearly see influence of the outage on different satellites. It was done on base of 1.2m dish. On some satellites it was real drop of the signal till total 0, on some satellites there were considerable drop of the reception. ScreenHunter_207 Mar. 02 22.29.jpg
Reactions: TheKrell
In the past I made some experiments during sun-outage periods. Results of one of them represented on the picture. You can clearly see influence of the outage on different satellites. It was done on base of 1.2m dish. On some satellites it was real drop of the signal till total 0, on some satellites there were considerable drop of the reception. View attachment 137856
Are they the satellites I think they are and are you seriously in Riga, Latvia?
Longitude does not really matters, main is Longitude. So, Sun-outage effect in Latvia is more or less same as people in Canada have. Sun-outage timing in Florida, of course, takes place in different time, but not in May, that is for sure.
Reactions: TheKrell
I don't know that any satellite is going to have enough power to overpower the SUN. For any specific satellite to any specific receive point, the outage is generally only going to last minutes, so you'd have to be watching a channel that's on the satellite that is directly in front of the sun as it relates to your position on earth.
The beamwidth of the small dishes also is a factor as well as the power of the satellite transmission, etc. I haven't seen or heard of any outages of DBS satellites in quite a while.
That time length depends on the size of the dish, and how "wide" an area (beamwidth) it can see. A 10ft or 12ft dish sees a smaller spot in space, so actual Sun outage would be a bit shorter in length.
p.s. Uh, JSheridan beat me to the post button, lol.
Again, you'd have to be watching a specific channel at a specific time in order to see the interference. I just used this calculator and the difference between a satellite at 119 degrees vs one at 129 degrees with a 1.2m dish at my home is an hour, with the longest duration 8 minutes. Unfortunately, both sats hit the outage in the afternoon when I'm not home to see it.
If you were home you probably wouldn't see any outage. We have channels from DISH playing here all day on several TV's and haven't seen any sun outages in a very long time.
I'm very familiar with sun outages from the C Band days, thank you.
The few times I've paid attention over the years, I've seen an occasional drop from HD to SD or a switch from 61.5 to 77 for a couple of minutes about the time the outage calculators said I should see an outage. Back in my C-band days, the outages were an "EVENT". Now with DBS, if anything, they're just an "event".
About the only way to get around sun outages is to stream. I learned about the sun outages back in 1985 when I got my big dish. That will always be the case in the Spring & Fall.
Installation Options (Generally) for Three Story Condo Building
Starz/Encore soon to not be available in the AT250?
