Is there a simple answer? I have a 1000.2 WA dish and two 211K receivers. Is there an LNB that will feed the three satellites down to the receivers using a single cable to each or do I need as switch?
If you are in California all you need is a western arc LNB. No switch needed, it’s all built in.Is there a simple answer? I have a 1000.2 WA dish and two 211K receivers. Is there an LNB that will feed the three satellites down to the receivers using a single cable to each or do I need as switch?
And before anyone asks, the same thing also applies to Western Arc users who are not in California.If you are in California all you need is a western arc LNB. No switch needed, it’s all built in.
I was alluding to the fact that he lists himself as being in California, nothing more...And before anyone asks, the same thing also applies to Western Arc users who are not in California.
