MT2 Module missing channel
the mack
1,479
483
HOCKEYTOWN
One of my two 722k's ota modules is missing the main channel CBS 62 but receives the sub channels just fine. It gives the signal lost message.
Do not think it is a antenna issue as the other 722k and 211k on the same antenna work fine as do the subchannels on the one in question.
The signal on the subchannels is in the high 90's. Adjusted the antenna to make sure it was not overloaded or a multi path issue.
I can only assume the module is bad?
Have you tried re-scanning your locals, to see if that brings back the main CBS 62 channel?
I have. But now that I think about it I did not delete all channels first. I know it can be a factor because the 211k I take on the road still has the out of area channels on the list after a re-scan. I don't use this receiver much and maybe there was a repack since I used it on channel 62. The only time I ever watch that channel is for football.
Reactions: TheKrell
Hopper and OTA EPG question
1000.2 EA, best way to aim?
