My Dish VIP722k receiver started to checking switch installations and satellites on TV 2, interrupting my programming on TV 1 as well, this screen appearing on both TVs.
722's have a history with losing the ability to process signals correctly, too. That could be your issueMy Dish VIP722k receiver started to checking switch installations and satellites on TV 2, interrupting my programming on TV 1 as well, this screen appearing on both TVs.
I have seen this before, back when I still had a ViP722k. I was able to fix the issue by simply replacing the separator attached to the back of the receiver.722's have a history with losing the ability to process signals correctly, too. That could be your issue
...since simply disconnecting and reconnecting the cables may fix this. If that still doesn't work, I have a spare separator that I could send you if you want to try replacing that.You might want to start by ensuring both connectors to the satellite jacks on the back are tight.
Interesting. First I had my 612's get flaky on their second tuner. Dish replaced both. Then my 722 went all squirrelly with decoding the stream, and I had that replaced as well. I never replaced the separator on any one of those receivers, and the new receivers worked fine until I "upgraded" to the H3.I have seen this before, back when I still had a ViP722k. I was able to fix the issue by simply replacing the separator attached to the back of the receiver.
