dish anywhere channel guide
Either your a new customer and your receivers haven't had time to populate the app or your not using hopper 2 or hopper 3 receivers..Your seeing the streaming channels only...Notice the little 2 green lines next to the channels..on the app if you go to streaming it shows the green lines..make sure your on (See All) at the top
Thank you and others for the replies. You are correct. I do not have the hopper system and am using the 612 receiver. I did find out that the channel numbers including local channels appear if I select the shows option on the channel guide but then I see that this function is not supported with the 612 receiver. I'm ok with that and will just continue using it as is. Apparently I cannot get the local channels on the anywhere app unless I upgrade to the hopper system. I am reluctant to change because at almost 90 years old I often have problems with new stuff.
Right now they're swapping people over to our hopper3 for free and adding credits to where your bill stays the same as it is now for two years.
Aligning dish
Mission stations back on DISH.
