Starlink and Dish OnDemand?
reubenray
1,557
1,342
Bella Vista, Arkansas
With the current sale on the Generation 3 antenna (?) and the 50gb for $50 roam plan I am thinking of getting into Starlink to use with my RV. I don't think Starlink will work at my home. But will Dish OnDemand work with my Dish Wally?
I do not doubt you, but I'm curious why Starlink will not work at your home.
From what I have read since making that comment Starlink would most likely work at my home. When Starlink first came out I could not get a Northern view for it due to tall trees. When I get back from my next trip I will test it out being I will still have days and gb to use.
Sorry to change topic but since I have not been able to find answer on starlink site, how much are additional GB?
all you need to do at the house is use the app for coverage test--50gb unless you are just emailing and face booking will get eaten up very quickly and it will shut of automatic unless you purchase extra gb's at $1 per gb and doesnt the wally still require the use of the dish--i would think you would have to access on demand directly through star and a computer or phone like dish anywhere-could be wrong how those work as i have never used either (on demand or anywhere)
I normally set up my Dish at home to get access to my DVR. I would check my laptop to see if Starlink works. I did the coverage test years ago and it showed frequent interruptions.
Will a standard RJ45 female/female coupler work with the gen 3 Starlink ethernet cable? I am wanting to get a short Starlink (6'6") cable to just get from my RV compartment to the outside. From there I would connect the Starlink cable to the antenna (?).
Pardon my naiveite, but is this the closest thread to a Starlink thread? I'm considering researching using Starlink with my RV (I only use it twice a year). I currently use a Dish Hopper for this purpose (because I can subscribe & unsubscribe) . I have Cable TV @ the house. However, I keep getting good feedback from campers on Starlink internet performance. I'm thinking about trying it with my RV, if I like it , I'd cut the cord to my house cable and use it at home as well. (Realizing I'd have to pay for some of the premium channels via internet apps, I'd have to research but I'd guess its more economical. Is there a thread for this subject or should I start one? Thanks
I'd do it. You can even get one that works while driving.
If it were me I'd permanently mount an antenna on top of rv and buy a second antenna at home that way all you have to do is move the modem only. However if you currently have cable internet the starlink won't be as good performance wise. Depending on how much you're streaming and what resolution you may not notice a difference though.
The only problem with that is each dish requires its own paid subscription.
the modem is the dish--you would need either 2 separate kits (2 separate bills) or one kit with a residential plan and you can change your service address to wherever you camp then back to your residence--only issue with that is tearing it down and reinstalling it each time--also there are areas now that are getting a 1 time $100 congestion fee in some areas if you want a residential plan and also some areas are being wait listed again for residential so your only option in that case will be a roam/mobile plan right away which costs more than residential and has less priority
The dish is not the modem. The modem is the inside unit. Like in my previous comment I don't see how switching between dishes would matter unless theyre somehow assigned to each account/modem once installed. If on a roaming plan then the location wouldn't really matter. But yes would cost more.
The inside unit is a simple POE router.
The all the important stuff is built into the disk.
With the current model you could use a POE injector and hook an Ethernet cable directly to the dish and your device and have your internet connected.
you would be incorrect--the modem is in the dish--the only thing in the house is the "router"--the dish has a unique serial number and also has gps location programmed into it which in turn shows the location of the dish at all times when on and they will and do know if you are in a wrong address for a residential plan and will block and notify you of such until you return to your registered address (or change the service address as i said then back when you reach home if your spot is still open for residential)
Keep in mind that if you use one system at home and then take it with you when traveling, you will not have any internet at home when away. Some forget about this, and if you have things like security cameras, temp monitoring, remote thermostats, or a list of other things that need internet access, they will be offline.
OTA USB stopped working on Hopper 3
Dish Anywhere Setup
