How do I replace a Hopper full of shows?
Luddite by Choice
26
22
Kennewick, WA
4 Dish techs have told me, beginning when it was new, that my Hopper 3 w/Sling is buggy. It's getting worse, and they tell me to buy a 2TB self-powered external HDD (no SSD or flash drive) for $60-$80, archive my Hopper contents onto it, replace the Hopper, then dump those EHD contents onto the new Hopper.
1. I can't find a self-powered 2TB EHD on the internet. They're apparently dinosaurs.
2. I'm not about to archive my Hopper onto an EHD unless I am sure I can retrieve its contents. I've lost too many entire Spectrum and Dish drive contents with "sure things".
3. What am I not finding? Are there any self-powered EHDs available that are simple plug and play (reformatting is OK, but anything beyond that is gobbledygook to this Luddite by Choice.)
2TB is the old standard. You can go as high as 7 TB now. And you don't have to transfer them to the new Hopper, just connect the drive as additional storage. That IS a sure thing - unless your Hard Drive is bad.
Regardless, I do want to remind people, when you record shows, you don't own those shows. They are only playable on Dish Hoppers. At some point, you'll probably leave Dish - hopefully not soon - and have no way to play those recordings.
why would you want a self powered drive there slower than ones that come with an AC plug??? there is a way to transfer shows via eithernet. that's providing the drive isn't bad then it won't transfer your shows and that takes days to do
The Ethernet method rarely works anymore. An EHD is the only way that works all the time
I've only used common WD Elements 2TB portable (bus powered) drives with my Hopper 3. I do plug them into a powered hub, which I believe makes them essentially self-powered as far as the hopper 3 can tell. At least I've had no issues using them.
self powered drives will get power from the hopper a usb port is all that's needed
I do that. But my EHDs are toast. Dish destroyed access.
I use a WD Elements 6TB HDD. It has a separate AC adapter for power.
Only issue is that occasionally, the nightly reset for the Hopper 3 results in not always seeing the external hard drive afterwards when pulling up the DVR menu, even though it's still plugged into it. Red button reset or unplugging/replugging the power cord for the external drive solves it though.
The annoying part of DVRs is that because recordings can only be saved on one drive at a time, if whichever hard drive you have your recording on fails, you've lost it. Doesn't matter if it's external or internal, because you can't duplicate the recordings as a backup.
You can backup and rearrange recordings if you wish. I have done it. The video and audio is encrypted but you can still move and copy files. Using a linux system is the most versatile way, but you could use a bit-for-bit disk copy to copy the entire disk on any platform.
Columbus Ohio Locals Interuption
number of joeys
