Hmmm i wonder if dish would switch it out
.. that's the dish they gave us on both installs... iv'e seen the reflector on ebay for like 23.00 smackers i'll have to look for the lnb
Nope, wouldn't switch it. This new model is only for new installs and only installers have it and won't sell me one.Hmmm i wonder if dish would switch it out![]()
Damm that sucks!!! id'e take the new model over the old HD dish or the slimlines anyday!!! even works when it's raining out with high winds!!! have you tried an independent contractor to get oneNope, wouldn't switch it. This new model is only for new installs and only installers have it and won't sell me one.
This dish in the pic measurements are bigger than the old Dish 500+. I think the new Western Arc model with the new twin LNBs is a Dish 500 size, 22.5 x 20.![]()
Dish Network 1000.2 (Dark Gray) Reflector Only 25" x 20" 142416 New | eBay
Item Title: Dish Network 1000.2 (Dark Gray), Reflector Only.www.ebay.com
Yes. HipKat company has the new model but not allowed to sell them.Damm that sucks!!! id'e take the new model over the old HD dish or the slimlines anyday!!! even works when it's raining out with high winds!!! have you tried an independent contractor to get one![]()
Boy the lnb eyes are much bigger then the triple lnb. I wonder if the strength of signal is any higher with this one, since you don't have to see all 3 anymore?View attachment 186302here's the new LNB.. it goes onto a dish 500 hybrid pro setup real easy to install
I think the signal levels are the same as the triple LNB i could be wrong.. I also heard people that have hoppers and the triple LNB that when doing the check switch it screws with the hoppers since it can't find the 129. if they didn't send a firmware update out yet they will be doing so..Boy the lnb eyes are much bigger then the triple lnb. I wonder if the strength of signal is any higher with this one, since you don't have to see all 3 anymore?
I wonder what the sat on order will replace. if charlie goes through with itThat's going to be the "old" 500 dish (110/119) that came out in 1998 but with the newest LNBF to handle all the newest rx's.
I think the signal might be a bit better without the added 3rd slot. The 1000 dish was just a bit small for its job and 129 was weak to begin with, so by time you got 129 maxed for what you were going to get, the 110 and 119, while stronger, might not have been optimal. Might be a giod tome for anyone with a 1000.2 to recheck alignment with just 110 and 119
They aren't. The EA signals are lower than WAI think the signal levels are the same as the triple LNB i could be wrong.. I also heard people that have hoppers and the triple LNB that when doing the check switch it screws with the hoppers since it can't find the 129. if they didn't send a firmware update out yet they will be doing so..
I really hope you aren't pointing at the WA with the EA LNB you posted, which is a 1000.2 LNB for a 1000.2 Dish.
THIS is the DPH Twin WA LNBF that goes on the 500 Dish kit
View attachment 186361That's the LNB we got!!! Maybe i should snap a pic of the eyes to!!!
I was expecting to see a onetech van pull upJust so you know, Dish does not send out a separate sales person. The installer is the sales person.
