Cold weather signal loss
Stay out of the pool!
shades area GIF
When the weather gets below 5 degrees, I lose the satellite signal. When it warms up to 10-15 degrees everything returns to normal. What could be the problem? LNB?
I live in Minnesota and I have the exact same issue on the satellite dish mounted up on my roof, but it has to get down to below zero. Once the temp falls below -10 or more, I lose signal. If you look at the signal strength screen, it will jump back and forth from 79 to 0, no in between. The LNB up on my roof is a Hybrid and feeds my Hopper 3 and 2 Joey 3s. I know it is not the Hopper 3 as I used to have a Wally connected to it and it did the same thing.
I have a second dish mounted on the side of my deck that has a DPP LNB and this feeds my Wally. It never loses signal even when the temp falls to -20 with wind chills to -40.
Generally sat electronics work better in cold, not worse. These described issues of sudden unexplained loss in cold sound exactly like the postulated too-short coax center conductor- physical contraction of circuit elements. Possibly something in the LNBF could be contacting and breaking circuit.
Festivus - Airing of Grievances
