Pansat 2800A
princeferoz
8
Does the Pansat 2800A replace the Pansat 2700A?
Also, is it possible to setup 1 dish with 2 receivers for 2 tvs to watch different programs at the same time?
Which receivers do you guys recommand to receive broadcasting from these satellites:
61.5°W EchoStar 3 / Rainbow 1
63.0°W Estrela do Sul 1
65.0°W Brasilsat B2
70.0°W Brasilsat B1
72.0°W AMC 6 / Nahuel 1
72.5°W DirecTV 1
74.0°W SBS 6
79.0°W AMC 5
82.0°W Nimiq 2
83.0°W AMC 9
84.0°W Brasilsat B3
85.0°W AMC 2
85.1°W XM 3
87.0°W AMC 3
89.0°W Intelsat Americas 8
91.0°W Galaxy 11 / Nimiq 1
92.0°W Brasilsat B4
93.0°W Intelsat Americas 6
95.0°W Galaxy 3C
97.0°W Intelsat Americas 5
99.0°W Galaxy 16
99.2°W Spaceway 2
101.0°W AMC 4 / DirecTV 1R/4S/8
102.8°W Spaceway 1
103.0°W AMC 1
105.0°W AMC 15
107.3°W Anik F1 and Anik F1R
109.0°W DirecTV 9S
110.0°W DirecTV 5 / EchoStar 8 and 10
111.1°W Anik F2
113.0°W SatMex 6
114.9°W Solidaridad 2
115.0°W XM 4 / XM Rock
116.8°W SatMex 5
119.0°W AMC 16 / DirecTV 7S / EchoStar 7
121.0°W EchoStar 9/Intelsat Americas 13
123.0°W Galaxy 10R
125.0°W Galaxy 14
127.0°W Galaxy 13/Horizons 1
129.0°W EchoStar 5 / Intelsat Americas 7
131.0°W AMC 11
133.0°W Galaxy 15
135.0°W AMC 10
137.0°W AMC 7
139.0°W AMC 8
148.0°W EchoStar 1 and 2
Thanks.
I believe the 2800 is just the 2700 with Component outputs.
As for a receiver that receives all those sats, a 2800 would be fine. Remeber though the Bell, Dish and directv sats don't have much FTA.
I personally use a pansat 3500sd now. I have used a Fortec Merc II and a Coolsat 5K. All three worked great and control my motor just fine.
How do I hook up 2 tvs to watch different programs at the same time? What do I need to do this? Thanks.
pretty much
These satellites are either C-band or not beaming here
65.0°W Brasilsat B2
70.0°W Brasilsat B1
84.0°W Brasilsat B3
92.0°W Brasilsat B4
99.0°W Galaxy 16
99.2°W Spaceway 2
102.8°W Spaceway 1
125.0°W Galaxy 14
131.0°W AMC 11
133.0°W Galaxy 15
135.0°W AMC 10
137.0°W AMC 7
139.0°W AMC 8
For the best results, you would use a dual output LNBF (such as the Invacom QPH, which actually has four outs, two each for C and L). This way, you could watch different polarities with each receiver. If you want to watch channels that are all on the same polarity, you could use the loopthrough IF output on the first receiver to send the satellite signal to the second one.
If you use the Invacom QPH, I recommend a 4 x 4 DirecTV-style multiswitch. This would allow you to see both polarities on both circular and linear satellites with up to four receivers.
NASA Feed on FTA?
FTA Newbie needs some help and advice
