Doubled HD programs
shodobe
606
4
NorCal
Any way to delete the HD channels that are doubled up? This just makes the HD channel listings longer when in fact there 2 of most channels.
Create a favorites list that has just the channels you want.
You can't do anything to the built-in lists.
Yes. Menu-6-9-Chan Display-Dish HD Channels-DISABLE.
It does not make sense that you have to go through Local Channels, but there it is.
You do not have to mess with locks or favorite lists. This will remove the 9*** duplicates.
But to get rid of channels like the extra HD RSNs, you'll need to go through the lock procedure.
There is a way in the menu to get rid of the map down channels. You will keep the 94xx channels, but their cooresponding lower channel number won't appear.
I think its over in the menus where you set up your antenna channels. (odd place to put it).
Yes, covered that.
811 NVRAM Reset
