We Need Your Help!
Boise, ID
This is our FOX station:
5253
KNIN (11)Caldwell, ID - CW, 11MPEG4 HD129°W048PSK (2/3)[SIZE=-2] Spotbeam 11[/SIZE][SIZE=-2]Boise, ID[/SIZE]Available
This is an independent station, with no network affiliation:
5255KTRV (12)Nampa, ID - FOX, 12MPEG4 HD129°W048PSK (2/3)[SIZE=-2] Spotbeam 11[/SIZE][SIZE=-2]Boise, ID[/SIZE]Available
7138KNIN (11)Caldwell, ID - CW, 11MPEG2 SD110°W25QPSK (5/6)[SIZE=-2]Spotbeam 41[/SIZE][SIZE=-2]Boise, ID[/SIZE]Available
This is an independent station with no network affiliation:
7140KTRV (12)Nampa, ID - FOX, 12MPEG2 SD110°W25QPSK (5/6[SIZE=-2]Spotbeam 41[/SIZE][SIZE=-2]Boise, ID[/SIZE]Available
5192WXXV2 (6)Gulfport, MS - FOX, 6MPEG4 HD61.5°W 208PSK (3/4)[SIZE=-2] Spotbeam 62[/SIZE][SIZE=-2]Biloxi, MS[/SIZE]Available
6592WXXV2 (6)Gulfport, MS - FOX, 6MPEG2 SD119°W 02QPSK (7/8)[SIZE=-2] Spotbeam A14[/SIZE][SIZE=-2]Biloxi, MS[/SIZE]Available
WXXV2 is NBC
6591WLOX2 (14)Biloxi, MS - ABC, 14MPEG4 SD61.5°W 208PSK (3/4)[SIZE=-2] Spotbeam 62[/SIZE][SIZE=-2]Biloxi, MS[/SIZE]Available
6591WLOX2 (14)Biloxi, MS - ABC, 14MPEG2 SD119°W 02QPSK (7/8)[SIZE=-2] Spotbeam A14[/SIZE][SIZE=-2]Biloxi, MS[/SIZE]Available
WLOX2 is CBS
5194WMAH (16)Biloxi, MS - PBS, 16MPEG4 HD61.5°W 208PSK (3/4)[SIZE=-2] Spotbeam 62[/SIZE][SIZE=-2]Biloxi, MS[/SIZE]Available
6594WMAH (16)Biloxi, MS - PBS, 16MPEG2 SD119°W 02QPSK (7/8)[SIZE=-2] Spotbeam A14[/SIZE][SIZE=-2]Biloxi, MS[/SIZE]Available
WMAH PBS virtual channel 19 real channel 16
will do.
The channel numbers are in the data stream and we can't change them
thanks
Jackson Tennessee market lists WBBJ3 as ABC. It is actually a subcarrier of WBBJ (the ABC affiliate) and it carries the CBS network programming.
Memphis Tennessee market lists WPTY as being in West Palm Beach, FL. If it is, they must have a mighty tall tower. :D
will do
thanks
5253KNIN (11)Caldwell, ID - CW, 11MPEG4 HD129°W048PSK (2/3)[SIZE=-2] Spotbeam 11[/SIZE][SIZE=-2]Boise, ID[/SIZE]Available
will do
thanks
Louisville, KY. Has a double listing for 9102, the second one should be deleted. The rest look OK.
The uplink program defaults to the primary call sign when one of the new digital sub-channels is missing from the station table and will duplicate the primary call sign and affiliation.
There were thousands of edits so I would expect to see more errors.
Station locations are as registered in the FCC database (when found in the FCC station table).
The uplink program does not recognize station affiliation changes so we need to enter them in the station table manually. Your feedback when changes occur will keep "THE LIST" current.
