I have noticed every so often on the local channels (the main ones use transponder 4 in my area) that it will go out all of a sudden and a box pops up indicating the signal has been lost just for a moment then goes away and goes back to the show again. There is no pixellation when this happens.
I replaced all my wires, the DP-34 switch, and get a good signal of around 80% and the problem still happens. I have noticed that it does it on two receivers at the same time (each on a different local channel on the same transponder). I then knew that it was not my receivers at that point.
I also have a PrimeStar dish pointed at 105. I hooked it up to one of the receivers, done the check switch, then checked to see if I had any issues that way. I noticed that the receiver connected to the PrimeStar dish did the same thing at the same time as a receiver I had connected to the SuperDish. That rules out my wiring and dishes to be the issue.
Someone told me that he was also noticing the same thing so I told him to write down the time that it happened and I would do the same. We both viewed the same channel at the same time and that box indicating that the signal went out came up on both of our receivers at the same time. He lives just up the road from me.
Has anybody else noticed anything such as this? I was hoping I could find some people on here that could write down the time and local channel they are watching when this happens to see if this is something that may be happening in just one small area or all over the DMA. I am in the Charleston, WV DMA.
