311 & DPP Problems
Chavez
185
Milky Way
I am having an issue with a satellite. I have the mast plum, I set the dish to the desired skew and elevation. My meter reads 110 & 119 with solid signal. When I do a check switch only 119 shows and the next ports display conn w/ x and conn w/ x. I tried replacing using DP LNB with the same results; also replaced all fittings, and did a line by-pass all with the same results. Any ideas...I am thinking this is the receiver?
Cover the right lnb with tin foil and make sure you are seeing 119 with the left lnb (viewing from behind the dish).
Your azimuth may be off.
My guess is that you are seeing 119 with the 110 lnb and thusly need to move the dish about 9 degrees left (East).
Olevia 242 T11 codes
What are my options?
