322 dual tuner
hines72
4
i have a dual tuner 322. i also have a twin "legacy" lnb for 119 & 110. i have a single "legacy" lnb for 61.5. how do i connect them for viewing on 2 tv's?
You would need a legacy switch. You would be better off to purchase a DPP twin and DP dual. That would connect all three satellites using one cable to the 322.
To answer your question you would need to replace the single with a DUAL not a TWIN and then you can use 2 SW-21 switches.
The 322 requires that both incoming signals are identical, in other words you couldn't have 61.5 on 1 input but not on the other.:) I agree a DPP Twin would be a better solution.
