I moved to Dish on Saturday after dumping D* (4 years). I have a 622 and 2-211's. I have 622 hooked to OTA so I can get by PBS HD.
On 622 when I am watching HD content on any of the 94** channels my video format is set to "Normal". Then when I move to any other SD channels (say 301 HBO) my video format is stretch which is good, I want it that way.
But then when I switch to my local SD channels say CBS/NBC/ABC/FOX my video format is "Normal", I see the black bars on the side so it is same as my HD format. If I change that format to stretch and move to any HD channels on 94**, the video format on HD's is stretch and I have to readjust it to "Normal".
It does not happen on 211's. On 211's all my SD's are stretch and all my HD's are "Normal". Also on 211 clearly see two options one for HD and one for SD, on 622 I do not see that.
I called the Dish tech support, they transferred me to advanced tech support, the guy had no idea either and said to me that since I have my HD resolution set to 720P I may be getting that and they recommend using 1080i, that does not make sense. I like to watch NFL on FOX on 720P as the broadcast is 720P. The tech guy then offered me a replacement 622 and if the replacement did the same, then he will send it to engineering as a defect.
Has anyone experienced the same? My wife does not care about SD/HD and she is still used to watching local channels using the regular channel number in NY area so when she goes there she see the black bars.
I am on software version 365 and something else is on 289, as per the Dish support I have all latest versions on 622. Also the PQ on HD is not same as my D* HR10-250, D* was better, I am using the same cables and same inputs as D*, I guess I will have to play little more with 622.
