942 extended guide cutoff
softwiz
SatelliteGuys Guru
146
I use the "extended guide with video" and the last entry in the guide is cutoff on the bottom of the screen. I'm using 1080i.
Anyone else seen this or can it be explained?
Yes, other are reporting seeing this (like me). It is also being reported that this is caused by your set (and my set) have to much over scan...
So if you know how to correct the over scan on you set you can fix this.
