Adding a Joey for Football; question
gadgtfreek
22,105
865
Lower Alabama
I have two lines running in, one for each Hopper. Can I just connect the Joey into one of these instead of the Hopper
Or do I need to use this guy on one of the lines?
The Duo Node is outside, the top image is where everything comes in and luckily is right where I need to connect the Joey as well.
If the running a wire from the Node Client port isn't an option then Yes the Tap will work.
Just make sure the Hoppers are powered down when messing with the Coax.
They get all fumbled up other wise..
Then Plug in each Hopper one at a time, let them completely boot up, then Hook up the Joey and power it up.
Question BB Connector Wifi and my 722
500 Plus dish/EA questions
