I have a CW600s rcvr and a GS120 which I bought recently. the motor is hooked up with a Winegard 76cm dish and a QPH LNB. the post is plumb and the dish tracks fine from H-2-H (yes, I have sat there on the roof with my analyzer and moved the dish from east to west and verified that it tracked almost every sat that was up there). and motor's 0 reference point is pointing to the true south for my location (zip code 95123). I have manually found a few satellites (IA5, G10R, AMC3). Now when I try any of the two available possibilities, USLAS or DISEqC to move the dish to the other satellites, either nothing happens or the dish goes to the far east or west and sits there.
If I understand these protocols correctly, they are supposed to do this? Also when I move the dish using the controls "continuous move", automated move" or "step move" and bring the dish to a position where I know there is something up there, the signal strength meter is stuck on 67% and quality is 0. I have noted that there are several people on this forum that have a similar setup and I am curious to know how you guys set it up? And whether or not you can use USLAS or DISEqC to jump from sat to sat?
Thanks in advance!
Thanks in advance!
