I have this setup (see image)
The setup using Ch3 works perfect, but the one using Ch4 gets static sound/snowy signal on the distant TV. Each TV is in separate rooms. I upgraded from old 501's to 612's. the Ch3 setup was in place since the 501's were installed, but the 2nd tv on CH4, I added after the tech finished the install of the 612's. I used my own Diplexers I had collected over time (from previous Dish Network installs.) I forgot to label the coax splitter properly, but it handles 5-950MHz. I've also removed the splitter and piped the TVout (CH4) directly to the diplexer and still get a bad signal.
Oh, and not pictured are the Dish combiner/splitters for Sat1/Sat2, they are in the appropriate spot between the diplexer and the 612's using the SAT connection on the diplexer.
Any suggestions? Thank you in advance. I've been a long time lurker, first time poster.
And, I was curious if I got some Dish Triplexers if they'd pass channel 3/4 back (the label says ch21-60something) but I didn't think that would cut off ch3/4 from passing through since you can also use that to send OTA signals (which include Ch3/4) through the same connection. It'd also simplify the wiring...
