Dish 1000 signal
tsduke
1,624
Iowa
What should I use as a baseline or what kind of signal levels should I be looking for on the 3 satellites for my area? I see some 50-60's on the 129. TP06 is currently 30.
After I posted this last night I went to bed and checked it on the 322. The 129 readings were higher than what I got on the 622. TP06 was in the 60's. What gives?
That's common. Different recievers will give you different numbers for signal strength. Various transponders will not even be used at all, so don't assume that a low transponder means that the dish isn't peaked well. If you get a warm fuzzy feeling from see high signal strengths, plug in a 311 and check 119 transponder 11 or 12. Should be over 110.
Caller ID on 211
