Dish DVR-921 assistance
jjthesniper
OK I have a Dish Dvr-921 receiver that has two satellite inputs. I also have a Panasonic 61 HD Projection LCD TV that has split screen capabilities. What I am wanting to do is, I know the 921 has PIP options, but I want it to be using the split screen. How can I (if possible) run another output from the receiver so that the second satellite signal, can run to a separate line on the TV. The is only 1 coax input on the TV, but multiple video inputs. If anyone knows of a way to do this let me know I would really appreciate it.
JJ
Thew 921 only has one output so you won't be able to use your TV split screen capabilites with only this receiver. Later DVR receivers like the 942 and the 625 do have this feature.
Keep in mind that with the 942 even though you'll be able to use your TV's split screen picture the second picture will be in standard definition since the receiver can only output to 1 TV in high definition.
Please Help To Install Dp34-119w-110w And 121w
942 Ota L2.83
