EchoStar 25 @110W as early as 1st Quarter 2026.
nelson61
8,884
9,061
Where it's Warm
EchoStar has filed with FCC for license and launch of the EchoStar 25 satellite at the nominal 110W slot.
------"At the nominal 110° W.L. orbital location, EchoStar is licensed to operate over 29 of the available 32 DBS channels (specifically channels 1-27, 29,and 31).3 Currently, EchoStar provides service over these channels from the 110° W.L. cluster utilizing the EchoStar 10, EchoStar 11 (in inclined orbit), and EchoStar 23 satellites; and from the 119° W.L. cluster utilizing the EchoStar 14 and EchoStar 15 satellites. EchoStar anticipates that EchoStar 25 will be ready for launch as early as the first quarter of 2026. EchoStar anticipates that EchoStar 25, a spot-beam satellite, will take over delivery of certain programming services from EchoStar 10 and 14. After launch and in-orbit testing ("IOT"),4EchoStar 25 will proceed directly to 110.0° ± 0.05° W.L. Once EchoStar 25 is placed into operation, EchoStar 10 will initially remain at 110.2° W.L. serving as an in-orbit spare and may ultimately be relocated subject to all appropriate Commission authorizations. EchoStar 14 will remain at the nominal 119° W.L. orbital location and serve as an in-orbit spare once EchoStar 25 begins service." -----
-----"The ECHOSTAR-25 satellite includes thirty-six 150 W saturated transmit power capability
TWTAs, nineteen 165 W saturated transmit power capability TWTAs, and two (2) 35 W
TWTAs for telemetry in contingency mode. At the nominal 110.00° W.L. orbital location, ECHOSTAR-25 will use up to fifty-one active transponders producing peak EIRP levels as high as 61 dBW for CONUS spot beams and 60.9 dBW for a Puerto Rico spot beam. "-----
Transmitting????
Content is king.
yes
FCC made some major upgrades to their records system this summer and I had to do some digging to find the right files..
A preliminary look at the contours using the ITU system indicates it is a conventional spot beam satellite similar to their other newer satellites.
It will take me some time to generate all the Google Earth spot beam contours. Will post a link when I finish.
For those that questioned HipKat's work on moving locals to Western Arc>
From the EchoStar 25 @110W license application.
"EchoStar believes that EchoStar 25 will be the most capable DBS satellite ever made in terms of beams provided and throughput. For example, due to its increased efficiency, EchoStar 25 will be able to consolidate two spot beam satellites into a single satellite and serve all 212 DMAs from a single satellite"
Wow. That is impressive. So does this mean they no longer need eastern arc sats? Or will they still operate the locals from both arcs still? I can't remember if they are still using that arc anymore or not.
EchoStar 25 at 110W
Ninety-three (93) spot beams
51 active transmitters
212 DMAs can be served simultaneously
Possible launch - 1st quarter 2026
Google Earth photo illustrates EIRP 50dBW coverage for each spot (50 probably covers reception with a standard diameter dish.)>
Half of the spot beams with transponder links are included in the Schedule S pdf and the other half will have similar transponder linkages.
For those that like these things, This link has the downloads for the 93 Google Earth beams.
  • EchoStar 25 Narrative (1).pdf
  • EchoStar 25 Technical Annex (1).pdf
  • Schedule S - DRAFT-SAT-LOA-20250717-00176.pdf
Are spot beams used only for local channel feeds?
I do not subscribe to any locals since I get them all OTA. So does this mean that down the road, I will only need to worry about signal strength and dish alignment from 119 and that none of my channels will be on the new 110 satellite?
Possibly for a while, but you never know.
Correct. 110 will be 100 percent spot beams for locals. 119w is the Conus satellite that will provide everything else.
This is going to be fascinating on how Dish is going to pull this off with the transponder space they have. I am assuming there is no way they will get their hands on the 11 transponders on 119 that are licensed to DirecTV. When they got rid of 129 the easy piece was to eliminate the SD duplicate channels and change all remaining SD channels to MPEG4.
Right now, Dish has the following:
119 (21 licensed transponders)
12 spotbeam transponders (TP 01, 02, 03, 04, 05, 06, 07, 08, 09, 10, 11, 13)
9 CONUS transponders (TP 12, 14, 15, 16, 17, 18, 19, 20, 21)
(transponders 22-32 are DirecTV)
110 (28 licensed transponders)
9 spotbeam transponders (TP 12, 18, 20, 23, 25, 26, 27, 29, 31)
19 CONUS transponders (TP 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 13, 14, 15, 16, 17, 19, 21, 22)
(transponders 28, 30, 32 are DirecTV)
You can see what I am thinking through. You can easily move the 12 spotbeam transponders to the 19 ConUS transponders. But if 110 is going to be all spotbeam, you have to move 19 ConUS to 12 slots on 119?
I mentioned in another thread, but I wouldn't be surprised if someday NBA League Pass, Center Ice, and Extra Innings go to a streaming only model, and the PPV's do that as well. Right now there are almost 5 full ConUS transponders used for that - 3 that are only used for the live sport events and 2 for the PPV movies and some other random channels. That would get you down to 14 transponders for 12 slots, and some other optimization would get it down.
EchoStar / Dish’s Path Forward
Horrible Install
