HD Audio Sync Issues?
DaveInPhilly
11
I was wondering if the problem is on Dish's end or mine. I have noticed that the audio on my HD locals does not sync with the video. Last night it was particularly bad when I was watching the SNL special on NBC. I thought it might just be a content thing, but when I switch to SD NBC the audio synced perfectly. I flipped through a couple of other HDs and noticed the same thing. The Audio was behind the video if that makes a difference.
I have a 622 (I think - HD DVR that also feeds a second SD set). Right now the video output is via component, and the audio is fed into the TV not the receiver.
Any ideas?
There is an HD audio sync somewhere in the setup menu. I'm not in front of my rcvr right now so I cant say exactly where it is located but I am sure it is in there somewhere
Soulwhat!:eureka
I had the same problem with OTAs a couple of days ago. All others were fine. Turned TV (Samsung RP) off, then on...it waited a little longer than usual, then all was well.
VIP622 Hard Drive
HDMI cable for my DishNet 811
