HD Connections (Comp Vs. HDMI)?
seanb
10
Forgive me, I know this is probably an ignorant question, but after hearing that DISH was upgrading to 1080p I had a question:
When I had my service installed the HDMI output on the back receiver would not work so we hooked it up using component video cables. The installer said it didn't matter because the signal DISH sends was not yet good enough for the HDMI cable to be an issue..
Soo.. is it an issue now? If I could use my HDMI port would I be getting a better picture then with my component video cables? My TV is able to receive up to 1080i and 1080p (don't know which of those is the better one..)
Component cable is capable of carrying 1080p. The issue may be copy-protection that's in the 1080p material. For that, you may need to use DVI or HDMI.
While component may be capable of 1080p, does anyone think that Dish will enable 1080p on component connections, especially since the only 1080p content will be VOD? I expect to watch 1080p content (edit: in 1080p), HDMI will be required.
Ted
Sooner or later (i.e.- sooner) studios will require DRM and down rezzing HD content sent over analog connections such as component cables. In fact, it's already being done in a limited way. It will spread.
Time to move to HDMI. Skip DVI if you can.
RSN's 24/7 HD
Scott, do you think??
