Help adding a third reciever
MIshler
52
8
ontario,ny
I currently have a 722 and 211 connected to a DPP twin and a DP single. I'm thinking of adding a third VIP receiver. I know I need a DP34. Can I use the 2 outputs from the DPP Twin or do I need to get a DP Twin to feed the DP 34. I assume the DP single must feed the DP 34 and not go through the DPP Twin?
A DP34 won't work unless you want to run two cables to your 722. You need a Dish Pro Plus switch probably the DPP44 seeing you have a DPP Twin.
The DP34 is not compatible with the DPP Twin (there are some documented exceptions) so you could get a DP Twin and use the DP34 as you describe.
Or swap for the DP Twin and get a DPP33 (also not compatible with the DPP Twin) instead of the DP34 which will save you from having to run another line to the 722. It will also allow you to upgrade the single-tuner receivers to dual-tuners (a 211 to a 612 will keep you at the lease limit of 4 TV outputs).
If you have an original Dish 1000, you could replace it with a 1000.2 which has an integrated DPP switch with 3 ouputs.
A Dish'n It Up upgrade through Dish will include the LNB and/or switch changes that may be needed as long as you're within the leased TV output limit.
Am I paying too much?
DPP44 & Diplexer for Cable TV
