Hook Up question
FredC
105
Chicago, IL
Hello all, once again I wish to pick your brains.
What I have: A Dish 500 w/ DPP Quad LNB, receivers: one 522, one 510 and one 508. I am replacing the 508 with a 625.
My question: I was told I could disconnect the 508, use the supplied "splitter" that comes with the 625, and only need 1 feed from the sat dish. Is this correct?
I have 2 feeds for the 522, one for the 510 and one for the 508.
If I have been mislead, what do I need to do? Someone said something about installing a switch. What kind?
Thanks again to all who help! Fred
you have a DishPro quad. There is no such thing as a DPP (Dish Pro Plus) quad
no you cannot use the separator on the 625 with a DP Quad. You would need to upgrade and there are 2 ways to do it
easier would be to get a DPP44 switch. You would run 2 lines from the LNB (DP Quad) to the DPP44 switch. Then you would only need 3 lines to the receivers
-one line ot the 522 and use the sparator
-one ine to the 625 and use the separator
-one line to the 508
The more difficult way is to get a DP34 switch. Hook two lines from the LNB to the DP34 switch. Then you would have 6 outputs (2 on the DPQuad and 4 on the switch). You would need 2 lines to the 522, 2 to the 625 and one to the 508
Iceberg,
I have 4 lines from the lnb. Can I leave 2 running to the 522, then put the other 2 on the DPP44 switch to run the rest? Or if I use the switch does everything have to run through it? The difference is I have 2 feeds that go into the basement for the 508 & 510, and 2 feeds in the attic for the 522. If all I have to do is put the switch on the basement feeds, that"ll be alot easier then going on the roof. Thanks for your help! Fred
Cleveland, Ohio locals in HD
622
