GEOSATpro How to add satellites from Asia & Pacific?
No user has provided data for your region, but we would love to include with a future update!
If you compile a list of satellites with only active transponders, email the .udf. We will add more satellites to the west.
he's new
being he's ku only at 157°w any sat below 87° he might not get
could he just change the lower ones to more westward sats by changing the longitude to say from 72°w to 166°e ? etc
theoretically he could get to 134.0°E
and use usal to get in the area needed
don't have this box but would work on a Pansat
don't try this till Brian answers this
ps. did you get a universal lnbf ?
would be needed for many of those sats to the west
I have a Geosat Pro SL1 PLL. It was the recommended on this post probably because it was a very good starting point since I am brand new. I can pick up one of those universal lnbf to use when pointing west - thank you for recommendation.
Is there a way to add satellites from Asia & Pacific? There were none found in the sticky threads.
You can use the Beamfinder tool here to understand which satellite signal you can receive at your location.
Added: On the microHD, it's easy to manually add new satellites from your remote control. Or you can edit satellites already listed and which you know you will never need since they're beyond your horizon.
GEOSATpro ON/OFF Reboot Looping
