How to swap remotes?
priester68
305
Natchez, MS
How can I swap my living room remote (20.0 IR) which recently got cracked with an identical remote in the bedroom (20.0 IR)
Both remotes are the same. Living room controls 722k, Bedroom a 222.
I don't care if the bedroom remote will be cracked because I don't use it much.
Thanks for any help.
Just make sure they're both on the same IR channel. If you use the 2-way remote feature, you will need to run it again so the living room STB recognizes it.
Actually, make sure they are on the IR channel that each receiver has been told...ie, if the 722 was set for say, 3, change the switched remote to same. 20.0 is not the learning remote, rather, 20.1
Switched to EA - rain fade
questionable billing practices
