I have issues
fletcher
I am having a couple issues:
vip211
will get distorted audio when I change channels not using guide, If I unplug hdmi and switch ports it corrects, it occurrs both hd and sd
My hd channels especially locals get intermittantly pixelated when not storming, it seams like each tuner does this without any pattern (vip622 dvr and vip211), SD this is not an issue. Could addition of DRV make this happen, seams worse since I upgraded to DRV receiver. I have had tech re-aim a couple times I have some trees to deal with but no leaves and clear weather still have intermittent issues. (sat 129 signal strength low 40s on both)
Tell me what you need to know about setup,thanks in advance
what's a vip21?
vip21
My hd channels especially locals get intermittantly pixelated when not storming, it seams like each tuner does this without any pattern (vip622 dvr and vip21), SD this is not an issue. Could addition of DRV make this happen, seams worse since I upgraded to DRV receiver. I have had tech re-aim a couple times I have some trees to deal with but no leaves and clear weather still have intermittent issues.
Do you mean a VIP 211? If you are getting pixelation on both VIP units sounds like a dish pointing problem. Give us some mor info about your system. Also so signal strengths on the sats.
Holiday Music
Need 129
