Well.. Its not the positions on the switch. When I initial came into the room, I had a 1000+ setup, with 118.7 being first on the switch. 110 was picking up USA HD (Law and Order: SVU). So of course, the first thing I did was disconnect all the inputs from the switch, and resorted them. I connected 110 to port 1 (channel was there at onset of test) then connected 72.7 to port 2, and 129 to port 3. I reset the switch and ran a check switch. The satellites listed in order on the matrix of the VIP922. Saved the results, cancelled out of the menu, and got to 015 (progress 2 of 5) and it hung there for about 5 minutes. Then moved to 3, hung for a couple minutes, and then ran 4 and 5 all kinds of quick. Program Guide download took FOREVER. LOL. At the end of it, USA HD was on 72.7, not 110. My test eliminates order on the switch. It also keeps the "lowest number" hypothesis alive, being that both 110/72.7 have USA HD. It also follows Mike123ABC's table thought as well, although the tables themselves are probably sent lowest satellite first.
Satellite number was 'verified' by pressing 'Info' twice.
