If the power supply for your antenna breaks, can you use a different one?
People love amplified antennas. While there's no substitute for a giant antenna on the roof, an amplified antenna can make the most of a small space. A clean, modern amplifier helps weak signals travel over a cable to your television without getting lost.
Today's antennas are designed to last for years. But, let's be honest. Sometimes things break. Sometimes you step on a cable or pull something out of the wall the wrong way when you vacuum. This can be true of the power supplies that come with antennas too. (We call them "power injectors," and I'll explain why below.) Unfortunately these power injectors aren't usually sold separately. So what can you do?
Amplifiers with a USB power supply
Many antennas and amplifiers, like Winegard's Elite antenna and LNA100 amplifier use USB cords for power. In this case you're really in good shape. You can use pretty much any USB charger. Generally even the cheap ones from the drug store will work. As long as the cable is intact, you can plug the cable into any charger cube and it will work. If the cable is the problem, you can replace it with almost any identical one.
Just be sure that you're using the right cable. For some reason a lot of antennas still use the Mini USB standard (at left) while pretty much all phone cables today use either Micro USB (at right) or USB type C.
Amplifiers with a coax power injector
We call power supplies that use a coaxial connection "power injectors." A power injector puts power on the same cable as the signal. The two don't interfere with each other because of some neat accidents of physics.
Unfortunately it's hard to find power injectors sold separately. Every time we get a good supply of them in different ranges they sell out quickly. So you might be stuck with what you can find. Should you use "the one you can find?"
This is an old power supply from a DIRECTV DECA. It might work in a pinch, but it might not. Here's how to tell.
The volts
Every power supply will have a rating showing the number of volts and amps it supplies. The volts are most important. You want a power injector that supplies the same number of volts as the one you're replacing. Too few volts and the amplifier won't work. Too many and the amplifier will run hot or burn out.
You can usually choose a power injector with a volt rating within 2-3 volts of the one you're replacing. If your old injector uses 12 volts you can usually get away with 10 or 14, but don't go much further than that.
The amps
Here you have some flexibility. You can use a power injector with an amp rating that's higher than your current one, just not lower. Remember it's metric, so if your current injector is 500mA, that's also known as .5A. You can use a 1A or 2A injector. The amplifier will pull the amps it needs to pull. If you use an injector without enough amps the injector will burn out quickly.
Examples:
Your old power injector says it is 12V, 500mA. Good choices for a replacement injector:
  • 14V, 2A
  • 10V, 750mA
  • 12V, 1A
Bad choices:
  • 6V, 500mA
  • 18V, 2A
  • 29V, 250mA
  • 12V, 250mA
It's still always best to use the absolute correct power injector but if you can't, this should help you get by in a pinch.
If your old power injector has a "passthrough port" but the new one doesn't…
You can use this splitter to put power into the line. Connect the power injector to one of the OUT ports, connect your antenna into the IN port, and connect your TV to the other OUT port. This is the same technology that's in the passthrough ports on other power injectors.
If you have other questions about antennas, call the experts! Solid Signal has a team ready to help with your antenna questions. Call us during East Coast business hours at 888-233-7563 or fill out the form below.
The post If the power supply for your antenna breaks, can you use a different one? appeared first on The Solid Signal Blog.
Continue reading...
Ken Reid and Joanne Rubino
Should you try a smaller antenna before buying a larger one?
