Installing a new Dish Turbo HD Dish
Garfield236
10
Phoenix
Hello I had the old Dish Pro Dish Network dish, and I know have a Turbo HD Dish Networks dish. I have a couple old receivers and a HD DVR reciever. The old Dish Pro connects to the switch. My question is - the new turbo HD dish has three outputs and a fourth one that says 'LNB In'. Do I just remove the old connections and plug in the three connections from 1,2 and 3 on the new Turbo HD reciever (I think it's called a 1000). Or do I need to be concerned about the fourth connection on the Turbo HD dish?
I also understand I point it to get satellite 110, 119 and 129 correct? :)
The LNB in is for a second dish. Each output is for one tuner each. When pointing it, cover the 110 and 129 LNBs with foil. This way you won't get the wrong satellite on the wrong LNB. Get the signal on 119 and peak it. Then do a check switch.
Pretty much right, the difference with your dish (probably 1000.2) is that it can run dual tuner receivers also. If you are pointing by covering lnbs, the 119 is in the center but gives direct signal feed out of port 1.
Anyone else have trouble paying their bill on Dish's Website?
Pausing on 722K
