little help....please.
tbhunter
Kentucky
Hi guys. I just purchased a DPP TWIN LNB Pro Plus Dish Network DPPTWIN 110 119 500. I will be connecting it to my 322 receiver that I will take from my house and use for our RV trips. I was told that I wouldn't use the one connection on the right. Do I need a switch or can I run a single coax from one of the 2 coax connections on the left of the LNB to my receiver? I will be running it to just one TV. Thanks alot for any help.
Yes you can run Directly from the Dish.
For Single wire use you must use a DPP Seperator at the back of your Receiver,
or you'll have to run 2 wires from the dish to the receiver to both tuners.
If you were wondering the output all the way to the right if for adding another single dish, so you can pick up 3 orbital locations without the use of a Multi switch, like a DP Twin would require.
Reuse Direct TV mounting?
Do you think the 922 is ready for prime time yet?
