They can not prosecute me for anything it is not illegal to move. it is only illegal for the dbs company to knowinly provide the signal. In other words what they do not know wont hurt them.
So the miami spot beam reachs north florida that is good. Not to doubt the poster who says it does when I posted this question at dbstalk I was told the miami spot only reaches as far north as melbourn. I know on E* the miami spot SD and HD does not reach Jacksonville.Ic an move with no problems I have family in miami so a billing and service address would match. I just do not want to buy the equipment install it and then find out the spot does not reach. None of my freinds here sub to D* so I can check the transponders. DOes anyone know if you can check the transponder on an D* receiver. I know on E* receivers you can check the signal strength on one of the menu screens. For example I can check the 119 sat and see no signal on TP 3 which is where the miami spot is located. I can go to best buy and check the location if its possible.
