motor home with VIP211
martha
22
colorado
I use a VIP211 receiver in a motor home and use a roof mounted Winguard 1000 auto dish. It works very well and receives the 110,119,&129. My problem is when using a single grounded mounted dish with a single LNB. I can easily lock on the 110 or 119, but for some reason the 129 eludes me. I have set the receiver for a Dish 300, 500,or Super. I don't see anything in the point dish stage. Any thoughts????? Martha
HI, what are you using for a meter? Maybe a check switch with the coax cable disconnected (to clear the receiver) might help. Later, DC
couple of pretty good ideas, i'll give a try. I looked at dish pointer as Tomboy suggested. You sure need a lot of clear sky to get from the 110 to the 129. Can't get the 129 at present location. The dish pointer gives co-ordinates for the 129. Question I still wonder will the VIP222 work with just the 129 only
Time Warner-Disney Dispute - Where is DISH??
Old HD markets - what's Dish gameplan re missing HDs?
