J
1) I have a vip 622. I can receive most of my local channels (except Channel 12, the local [Richmond, VA] NBC affiliate) using a "Stealth" OTA antenna left over from my VOOM days. (Richmond, VA is not on the list for the "free" OTA antenna supplied by E*)
2) From the LOCAL CHANNELS menu screen, I had to use the ADD LOCALS button and manually scroll through all the transmit numbers, pausing about 2 seconds on each one to see if I had a signal. The SCAN LOCALS button does not find any channels at all, probably because it spends less than 0.5 second looking at each transmit number. Anyone else observe this behavior with SCAN LOCALS?
3) I can find no hint of Channel 12 on any of the transmit numbers. Any way to find out how the transmit numbers are mapped to the local channels? If I knew where Channel 12 was, perhaps I could watch that transmit number and tweak the antenna until I got a signal.
4) Wednesday night during a rainstorm I was trying to watch "Lost" on the local ABC channel OTA in HD. I was getting a 66 signal strength but could not get a lock even though I was able to easily lock on another local channel with a 64 signal strength. Do factors other than signal strength affect the ability to get a lock? Also, this is the first time I remember rain affecting an OTA signal to the point where it would prevent a signal lock. Anybody else seen this behavior?
