Prof 7500 linux driver mods
  • Thread starter Thread starter updatelee
  • Start date Start date
  • Replies Replies 0
  • Views Views 3K
updatelee
1,604
113
CFB Edmonton
this modifies the stv0900 src so that when you tune a freq ( FE_SET_PROPERTY ) that when it does it's little adjustments, it saves those settings in the same u.data variables you used to tune with, that way when you do a FE_GET_PROPERTY you can actually pull the info.
the Prof 7500 search +/-5mhz for the signal, and +/-10000 SR, does auto system (dvb-s/dvb-s2/dss), auto modulation (qpsk/8psk), auto pilot, auto rolloff, auto inversion, and auto fec.
so you can put in super generic tuning info, then do a FE_GET_PROPERTY and pull all the specifics out so you can use it in your other tuners that dont do all that fancy stuff.
Code:
--- stv0900_core.c.orig	2010-06-21 13:12:09.032070510 -0600
+++ stv0900_core.c	2010-06-19 13:06:38.532428739 -0600
@@ -1629,6 +1629,15 @@ static enum dvbfe_search stv0900_search(
 		p_result.spectrum = intp->result[demod].spectrum;
 		p_result.rolloff = intp->result[demod].rolloff;
 		p_result.modulation = intp->result[demod].modulation;
+		// UDL
+		c->frequency = p_result.frequency ;
+		c->symbol_rate = p_result.symbol_rate ;
+		c->fec_inner = p_result.fec ;
+		c->pilot = p_result.pilot ;
+		c->rolloff = p_result.rolloff ;
+		c->modulation = p_result.modulation ;
+		c->inversion = p_result.spectrum ;
 	} else {
 		p_result.locked = FALSE;
 		switch (intp->err[demod]) {
Code:
--- stv0900_priv.h.orig	2010-06-21 13:12:58.282155848 -0600
+++ stv0900_priv.h	2010-06-19 13:11:08.361159042 -0600
@@ -185,7 +185,8 @@ enum fe_stv0900_modcode {
 enum fe_stv0900_fec {/*DVBS1, DSS and turbo code puncture rate*/
-	STV0900_FEC_1_2 = 0,
+	STV0900_FEC_NONE = 0,
+	STV0900_FEC_1_2,
 	STV0900_FEC_2_3,
 	STV0900_FEC_3_4,
 	STV0900_FEC_4_5,/*for turbo code only*/
motorized help
A-B switching, Power Issue?
